Hey, I have a 98 1500 3.9 liter v6 5 speed manual with 50 k miles. The other day I was leaving for work and as I went to shift from second to third my rpms skyrocketed, thinking that I accidently put it in first instead of third I pulled it back into neutral. Instead of my rpms dropping, they hit redline numbers. I've literally never heard my truck louder. I turned the truck off, parked and restarted it with the same issue, when I threw it into first gear the truck takes off without any gas needed. I was able to go through all my gears and limp home. Does anyone have an idea what the problem might be? There is no issue with shifting. Also, I had gotten my oil changed the night before and the guy working there said that the last time I got my air filter changed that the housing wasn't mounted properly. If anyone has any ideas as to what the problem is, I'd really appreciate it.
I checked the throttle cable and it looks like its bound up and slack. Is this something that needs to be replaced? or can I disassemble it and respool it?
Replace the throttle cable. It can not be fixed. And since it's stretched, you can't fix that regardless.
