My Project this weekend - Complete brake overhaul
Old Sep 22, 2012 | 10:10 AM
RageGuy's Avatar
RageGuy
Default My Project this weekend - Complete brake overhaul
Calipers, Rotors, Pads, Hoses, Drums, Shoes, Wheel cyls, drum hardware kit, cleaner and fluid.
Got All my bases covered I think. About $440 for the lot after core refunds on the calipers, not too shabby.
Any words of advice before I dive in?
I am expecting my drums and rotors to be in horrible shape, shoes down to the rivets, etc...I will post pics
P.S. The Cat is my assistant.
Old Sep 22, 2012 | 10:47 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
I would advise a complete fluid flush. DOT 3 should be changed about every two to three years.
Old Sep 22, 2012 | 11:10 AM
J415's Avatar
J415
Are you keeping the wheel cylinders stock or are you doing the 1 ton upgrade? Looks like you got your bases covered.
Old Sep 22, 2012 | 11:37 AM
RageGuy's Avatar
RageGuy
Thanks for the advice. I do plan to flush the fluid out with fresh dot 3 :-)
Old Sep 22, 2012 | 11:39 AM
RageGuy's Avatar
RageGuy
I got "Severe duty" cyls. I assume those are the 1 tons. They were the only ones available. 10 bucks per.
Old Sep 22, 2012 | 12:07 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
For future reference (and IMO) you're better off buying the caliper rebuild kits rather than buying new or refurbished calipers.
Also, you don't have your location in your profile, but I would also recommend removing the bleeder valves of the calipers and cylinders and applying a light coat of Anti-seize to the threads. Put just enough on the threads to make them silver-colored. That way they won't rust in place and will make future bleeding a breeze.
Old Sep 22, 2012 | 12:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'd check your cat too, looks like it is getting clogged.
Old Sep 22, 2012 | 12:53 PM
dlyter09's Avatar
dlyter09
LMAO i was getting ready to make a cat comment.. I dont think he will like having exhaust pipes welded in each end
Old Sep 22, 2012 | 01:01 PM
zman17's Avatar
zman17
When it comes to cats, I would like to weld exhaust pipes in each end. I'm a dog person if you cant tell. LOL
Old Sep 22, 2012 | 06:07 PM
1997DodgeRam's Avatar
1997DodgeRam
Master cylinder?
