Two Mysterious Noises..
I have some noises that have been goin on for awhile,may be related,maybe not.
1st noise- Driving through a parking lot,if i accelerate and bluntly let off gas pedal before it shifts into 2nd or 3rd, it shifts anyway and since rpms arent high enough it clunks. If i stay on the gas,shifts smooth. If i slowly deaccelerate it slowsdown without clunking.
2nd noise- Driving like 45+ mph on freeway or whatever, when i give it gas, it sounds like bad bearings or something. If i let of throttle sound goes away.Give it as,comes back. Only notice it at higher speeds....
Would bad u joints cause both? Transfer case? Has all new wagner brakes,plenum,timing chain..etc. Both were doing it before all work was done.
97 1500 5.9 4x4
Thanks for suggestions.
97 1500 5.9 4x4
The Thunk or Thud sound you hear as described is your your U joints on the drive shaft; when the pressure is high and shifts hard; (mine does this) shifts the pressure is decreased and shifts and engages hard.. you hear a thud sound. Also when you go from park/R or D/R changing direction of the draft shaft you hear the Thud- New U joints is needed. Mostly the one on the *** end most common. But sometimes it just happens because if the release of pressure then engagement..
On the 2nd issue; need better description of the sound; as they said a video would be best..
2nd noise,ill work on a vid..
