new to this website need some help with some questions asap please
Old Sep 28, 2012 | 09:28 PM
95RAM360's Avatar
95RAM360
That im not sure about the 1500s didnt have a 5spd trans for the 360...the one in the 5.2 is a nv3500....the 2500s had a 360good with a 5spd but it was a nv4500 trans...so im not certain if its able to bolt right up
Old Sep 29, 2012 | 04:17 PM
tylor2012's Avatar
tylor2012
That sucks lol
Old Sep 29, 2012 | 04:19 PM
Ham Bone's Avatar
Ham Bone
Should swap right in without having to change anything.
The NV4500 should fit either a 360 or a 318. As long as you have the gas bell housing
Old Sep 29, 2012 | 05:35 PM
tylor2012's Avatar
tylor2012
I have the nv3500 so u think the 360 bolt to mine what about wire harness will 318 harness fit 360 motor
Old Sep 29, 2012 | 05:41 PM
gdstock's Avatar
gdstock
Other than crank on one being internally balanced and the other being external, and PCM won't know what to do, and a myriad of other problems......as opposed to taking the advice given....and doing things the hard way.....priceless!
Old Sep 29, 2012 | 10:17 PM
Wombat Ranger's Avatar
Wombat Ranger
And you will need a new flywheel too...
(360 specific)
Old Oct 19, 2012 | 10:36 PM
tylor2012's Avatar
tylor2012
so new motor in took old motor apart an come to find out my number 8 intake valve was busted, the piston was coming up higher than others an hittine plug, the plem gasket an under side an inside no oil or caked up crud
