aftermarket suspension lifts
Old Oct 1, 2012 | 09:02 PM
dlyter09's Avatar
dlyter09
A full kit includes all steering components needed. I believe you can get a rough country lift for between 800-1000 for a complete lift.
Old Oct 2, 2012 | 10:07 PM
Blue Mopar01's Avatar
Blue Mopar01
Sorry to hijack this thread but does anyone have a pic of a dodge with a 4.5" lift on it? I'm looking at down the road, getting a tuff country 4.5" lift for my dodge and was curious on how it would look.
Old Oct 3, 2012 | 12:26 PM
silverram2000's Avatar
silverram2000
i installed the rough country 5 inch lift. the rear has blocks. i changed them out asap. put the bds 4.5 lift leaf springs in the rear. but the steering i changed out to the 98.5-99 1 ton t setup. havnt had to change anything else, yet. so i have about 1300 into the lift kit, the steering and the new lift spring. i am happy rolling around on the 36's. still get about 10-12 mpgs.
Old Oct 3, 2012 | 02:33 PM
americankaveman's Avatar
americankaveman
I'm really not engine savvy, all I know is that dodge ram is king and I wanna put it in the air without destroying the truck so y/how do u change the steering? Is there an advantage of leaf springs in the back over shocks? Beside price I mean.
Old Oct 3, 2012 | 05:10 PM
Matt Nickerson's Avatar
Matt Nickerson
Lifting more than 3" or so (suspension lift that is) will cause steering & suspension geometry to go more and more out of line the more you lift the truck.
Piece together all the right parts or buy a kit and you won't destroy much of anything (maybe unit hubs with giant tires..)
Changing the y steering setup to to a t setup is just an upgrade to a better design, not required.
Leaf springs over shocks? That makes no sense considering you've got and need both. Lifting the rear with leaf packs or add a leafs over blocks increases the safety of the truck. Big blocks like 5" ones can cause axle wrap amongst other things..not a common occurrence but can happen.
You can lift the front with coils and spacers and the rear with leaf packs, aal's, blocks, or shackle flip. Proper steering components (pitman arm, track bar, control arms, etc) all need to be upgraded to accomidate lift size.
Old Oct 4, 2012 | 04:23 AM
americankaveman
If lifting more than three inches will cause steering and suspension to go out of line, than what can be done to fix correct the issue? (If anything at al)
Old Oct 4, 2012 | 12:42 PM
silverram2000
the t-steering was easy to swap out. its from a 98.5-99. just get an alingment after you do the swap. and with the rc lift kit, they have you stack a 4" block on the factory 2" block. i didnt like it at all. saved up some money and bought the leaf springs.
Old Oct 4, 2012 | 05:40 PM
merc225hp's Avatar
merc225hp
Send me a pm on how much you would like/expect to spend doing this.
Old Oct 5, 2012 | 01:38 AM
Matt Nickerson
Its corrected by buying parts that accommodate your size lift... 5" lift requires parts like a drop pitman arm or a track bar bracket, etc.
Seven inch lift requires parts that go with 7" lift, etc, etc
Kits will come with all necessary parts, or you can piece all together if u know what you need.
Old Oct 5, 2012 | 12:00 PM
merc225hp's Avatar
merc225hp
A good kit will include EVERYTHING needed to do the job right, piecing a kit together is just stupid unless you have nuts, bolts, washers, vac-line, welder, cutting torches, and lot's of exp doing this type of job. The big parts are ez to deal with it's all the little pieces that you wont have that will drive you nutz doing the job.
I will not push Skyjacker but this will give you an idea what a full kit includes.
http://skyjacker.com/product.php?ProdID=25272
