Lacking Power under load
Old Oct 9, 2012 | 10:18 AM
Originally Posted by stewie01
I don't know of any blown plenum that did blow blue smoke.... I know mine didn't.
So you can be sucking oil into the cylinders and not burning it? I have no oil consumption yet, no symptoms of a blown plenum, yet (I say yet, cause I know it's going to happen sooner or later), but I figured if it started burning oil, then I know it's time to replace the plenum. I figured that would be an early warning sign before it gets to the point of actually clogging the converter, ruining O2 sensors and such.
Old Oct 9, 2012 | 10:24 AM
stewie01's Avatar
stewie01
I don't think it burns all the oil, but I could be wrong, it's happened before.
Old Oct 9, 2012 | 10:31 PM
ReadRam's Avatar
ReadRam
You most likely won't see the oil getting burned via the exhaust. It will show up on the dipstick, tho, that it's gone.
Old Oct 10, 2012 | 10:04 AM
nwracer45's Avatar
nwracer45
Here is the photos of my plenum. The oil stream on the side if from Gunk that I sprayed into the intakes to clean them. But there is alot of oil residue inside the plenum.
Attachment 17388[/ATTACH][/ATTACH]
Old Oct 10, 2012 | 10:18 AM
nwracer45's Avatar
nwracer45
Attachment 17390
Attachment 17391
Also as most has had this happen it broke two studs. The large one I think I can handle but does anyone have any ideas on how to get the short one out? It broke pretty much level with the block.
Thanks
Old Oct 11, 2012 | 09:18 AM
nwracer45's Avatar
nwracer45
The short one came out with a little heat and a bolt extractor. The tall one broke off short with the vise grips. The problem is that I can't drill into it. I have tried three different drill bit which are brand new and I get no where. It is like hardened steel. Anyone have any ideas?
