paper clip trick how?
Old Oct 7, 2012 | 07:23 PM
Deadlymopar408's Avatar
Deadlymopar408
Default paper clip trick how?
I have a 94 Dodge Ram 1500 w/ OBD1. Where do I put the paper clip in the port connection, or is their another way of finding out whats cause the check engine light.
Old Oct 7, 2012 | 07:46 PM
Jumper pins A & B. Top most right side of the connector. I'm not sure if this trick will work on a 94 Chrysler product. On my 94 Camaro, I had to purchase an OBDI scanner.
http://obd1.com/
Old Oct 7, 2012 | 08:40 PM
clipper77's Avatar
clipper77
You can try this
https://dodgeforum.com/forum/showthread.php?t=182034
Old Oct 7, 2012 | 09:42 PM
Deadlymopar408
well i found out the turning the key on and off 3 times works but to be really certain if the codes are telling me correctly does anyone know of a adapter for a obd2 scanner for these dodges?
Old Oct 8, 2012 | 08:21 AM
Depends on what scanner you have. I have an Actron 9185 that is both OBD1 and OBDII that I have an adaptor for to connect to the 12 pin (OBDI) connector.
Old Oct 8, 2012 | 08:29 AM
kejobe's Avatar
kejobe
Just stick the paper clip n the top right two holes of the obd port. Turn ignition on but DO NOT start it. The check engine light should start flashing with the codes.
IE. Flash, flash, pause, flash, flash, flash. This would be 23. Call your local parts store and give them you truck info and the codes. They should be able to tell you what they are.
I have done this in the past, but not any Dodges. Therefore Im not positive it will work, but would think it should.
Old Oct 8, 2012 | 03:09 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Why would you think the key trick is not giving you the correct codes? OBD1 doesn't have that many and a scanner will tell you know more than doing the key trick.
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
