Old Aug 4, 2015, 07:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
How do i tell which transmission is in my truck
Old Oct 9, 2012 | 06:16 PM
stewie01's Avatar
stewie01
This is what Wikipedia says and contradicts what I found earlier. So according to wiki he's got an RE.
46RH:
A renamed A518. A727 with overdrive and hydraulic control.
Applications:
1994-1995 Dodge Ram 2500/3500 V8
1993-1995 (Jeep Grand Cherokee 5.2)
1995 Dodge Dakota 5.2l magnum v-8
1995 Dodge Ram Van 2500 5.2L Magnum V8
46RE:
A renamed second-generation A518. A727 with overdrive and electronic control.
Applications:
1996 Dodge Dakota V8 (Also 98-03 Dakota 5.9L R/T)
1996-2002 Dodge Ram 1500/2500/3500 V8
1998-2003 Dodge Durango 5.9L V8 (4WD or 2WD)
1998 Jeep Grand Cherokee 5.9L V8 (4WD)
Old Oct 9, 2012 | 06:17 PM
I have a 97 1500 extended cab, 5.2L, 4X4 and my build sheet indicates I have the 46RE (DGTS 4-Spd. Automatic 46RE Transmission).
Old Oct 9, 2012 | 07:13 PM
Thornloe Pride's Avatar
Thornloe Pride
Thanks for the information. You do learn something every day..
Old Oct 10, 2012 | 04:15 PM
DodgeTh1s1's Avatar
DodgeTh1s1
46RH:
Applications:
46RE:
Applications:
thanks man
Old Oct 11, 2012 | 08:05 PM
NRambo's Avatar
NRambo
Default 1995 ram 1500 318 auto. Will a 98 trans fit?
I have a 1995 ram 1500 318 auto with the transmission seals blown out and I was ask if I could us a 1998 transmission.
Does anyone know if the 98 transmission will fit my old 1995 truck?
Old Oct 11, 2012 | 08:31 PM
Thornloe Pride
If I am not mistaken, you can put a 95 tranny in a 98 but not the other way around.
Old Oct 12, 2012 | 12:45 AM
HeikIlm's Avatar
HeikIlm
They don't work either way around. RE has 8-pin connector and speed sensor on OD unit, whereas RH has 3-pin connector and no speed sensor. So naturally both have their own harness and PCM.
RH might be drivable on '98 truck but wouldn't have OD or TCC , and since the PCM doesn't know what the heck is going on there will be fault light present. And because RE trans has electronic governor, it most definitely won't work on older truck. I don't think that you could even get past first gear.
There's also some difference in length
Old Oct 12, 2012 | 02:58 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Spot on. 94,95 only and maybe a 96. Gets iffy in 96. Just need to verify that the 96 is an RH for sure. And I would only use one out of a RAM.
And it has to also be out of a 4x4.
Old Oct 12, 2012 | 06:30 PM
jasonw's Avatar
jasonw
Site Moderator
You all could have saved yourself some time and used the FAQ section.
What Automatic Transmission Do I Have?
Old Oct 13, 2012 | 12:49 AM
gdstock's Avatar
gdstock
How did you discern that he has a 4x4? I missed that....
Oh yeah....take the easy way! (I was wondering why someone did not throw out the search thing..) I wondered how long it would take for someone to post that link ... and I thought it would be zman!
