A/C System Won't Accept Refrigerant
Old Oct 11, 2012 | 07:11 PM
Swamprunner's Avatar
Swamprunner
Default A/C System Won't Accept Refrigerant
Well, I finally replaced my bad heater core on my '96 318 2-wheel drive 1500. Did the whole tear out the dash thing, removed heater box and cleaned out the mouse nest, etc. I reinstalled everything correctly, as this is not my first rodeo. New o-rings on the refrigerant lines, new accumulator, and pulled vacuum on the system, holding for three days. No leaks. Tried to re-charge system and it will not accept new oil, or 134a. Yes, I started the compressor using a paper clip in the pressure switch connection, no soap. any ideas out there? Bad or plugged orifice tube maybe? Or something stupid that I forgot to do? A/C system was running great before I dismantled it. Thanks, ~Swamp.
Old Oct 12, 2012 | 02:37 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Sometimes the valve on the can punctures it but when you turn it back out it seals back up again. Are you using a good set of gauges or just the cheap one hose deal?
Old Oct 12, 2012 | 03:17 PM
diverjer's Avatar
diverjer
Maybe the A/C fitting isn't any good maybe your vac was just in the gauge hose? I don't know just throwing out ideas.
Old Oct 12, 2012 | 04:28 PM
zman17's Avatar
zman17
Delete....
Old Oct 12, 2012 | 05:53 PM
diverjer's Avatar
diverjer
Yea you wouldn't want to do that if compressor running.
Old Oct 12, 2012 | 06:04 PM
zman17's Avatar
zman17
Originally Posted by diverjer
Okay I changed it, was just trying to help someone do it faster and not have to short out switches. Yea you wouldn't want to do that if compressor running. Maybe you could delete your quote so no one sees it??
Jumping the low switch is fine just to get some charge in it. Just don't recommend the average guy on here screwing around with the high side, that's all. Quote deleted.
Old Oct 12, 2012 | 06:49 PM
diverjer's Avatar
diverjer
I understand and you are correct, many would not know what I meant.
Old Oct 13, 2012 | 04:18 PM
Swamprunner
No, I am using a good set of gauges, instead of the one hose deal. I am an experienced HVAC guy, and I have all of the neat tools.
Old Oct 13, 2012 | 04:23 PM
Swamprunner
Let me go out in the garage and check this....... . Hey! that was sorta it. I have a bad piercing valve. it did pierce the can, but it is not getting past the valve. Schweeet! Thanks! I guess my tools are getting some age on them, like me.
Old Oct 13, 2012 | 04:28 PM
Swamprunner
Yeah, I had a friend that did just that, and wound up busting a hose on the cheap set of gauges he had. Although, the service manual on my Lexus tells you to add gas to the high side after you pull it down, with the engine off, of course.
