Stick Shift trans help
Old Oct 17, 2012 | 09:31 AM
Mutt Bryant's Avatar
Mutt Bryant
Default Stick Shift trans help
Hey guys, I'm got a question and maybe even a line of questions about a transmission that I want to put in my truck. I talked to a guy and he has a stick shift transmission that was in his diesel dodge that he might sell. I dont even know if they made a stick shift for a gas burner but I hope to get one. Will the diesel transmission work in my gasburner? Also what all is involved in putting a stick into the truck besides the clutch kit clutch pedal? Also what computer wise needs to be done?
Old Oct 17, 2012 | 09:36 AM
jpsycoboy5's Avatar
jpsycoboy5
The diesel one won't mount up different bell housing. You need the wiring harness, pedals, crankshaft sensor, different length driveshafts, and a few other things I'm in the process of doing this swap right now do a search there are a lot of threads about this. The computer will be alright but you'll have a cel for tranny codes
Old Oct 17, 2012 | 09:50 AM
Mutt Bryant
Ah, so no diesel trans will fit the housing. That kinda sucks but I guess that means they make a stick shift trans for the gas burners. On another note, my truck is a 2500 which can be diesel or gas. Does that even change the not fitting the bell housing problem?
Old Oct 17, 2012 | 09:55 AM
jpsycoboy5's Avatar
jpsycoboy5
No it doesn't change unless you also swap in the oil burner. If you have a 360 I'd go with a ldnv4500 basically bullet proof and will bolt right up to your v8
Old Oct 17, 2012 | 10:02 AM
Mutt Bryant
So nv4500 is good. Got it. So how much will all this cost for all the other parts that need to be put it?
Old Oct 17, 2012 | 10:06 AM
jpsycoboy5's Avatar
jpsycoboy5
Um without a parts truck a lot haha you'll have to source all the parts and new they aren't cheap if you can find a parts truck cheap like I did its not to bad because you can sell/scrap what you don't use
Old Oct 17, 2012 | 12:35 PM
Mutt Bryant
Lol I definitaly aint buying new lol. Im way too poor for that mess.
