help with installation
Old Oct 18, 2012 | 06:04 PM
Devin Eberenz's Avatar
Devin Eberenz
Default help with installation
ive got a 97 4x4 ram 1500 with 14 bolt 4 speed transmission i have an egine light on and a code of p0753 i beleive its the shift selenoid i need help on how to install it, or if i need to take it to the shop i need to get my caroline in healthy oreder, the light came on and doesnt seem to be anything wrong when i drive it please help and thanks for your time
Old Oct 18, 2012 | 06:08 PM
jpsycoboy5's Avatar
jpsycoboy5
First off search haha but go to the DIY section and its in there it's really detailed and has great pictures. Next time search first but here ya go its not to bad I had to do it. I think the sonax sure cure fix eliminates the faults with this I can't remember I'd check it out though
https://dodgeforum.com/forum/2nd-gen...-solenoid.html
Old Oct 18, 2012 | 06:18 PM
Devin Eberenz
what is " sonax sure cure fix " what does it do what is it
Old Oct 18, 2012 | 06:28 PM
Devin Eberenz
did not find a diy on replacing the thing all i seemed to find is the cleaning the governer switch
cant find it anywhere its why im asking now
Old Oct 18, 2012 | 06:47 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Nothing wrong and drives fine you say? Try resetting the PCM .
Old Oct 18, 2012 | 07:56 PM
Devin Eberenz
how do you reset the pcm
Old Oct 18, 2012 | 07:58 PM
kejobe's Avatar
kejobe
Disconnect the battery, wait about 5 minutes, reconnect battery.
Old Oct 18, 2012 | 08:03 PM
Devin Eberenz
well what caused it to come on in the first place if its that simple to fix< or does that simply turn the engine light off? whats the problem
Old Oct 18, 2012 | 08:21 PM
gdstock's Avatar
gdstock
How is the fluid level? And how are you checking it? Go to the FAQ/DIY section and download FSM. Then search for Gove solenoid here...but you have to spell it correctly to get any good results.
Old Oct 18, 2012 | 08:46 PM
Devin Eberenz
typed in fsm did nothing
