46RE to NV4500 transmission swap on 1996 Ram 1500
Old Dec 8, 2012 | 03:01 PM
  #51
Wombat Ranger's Avatar
Wombat Ranger
Or put a spot weld between the nut and 5th gear...
Old Dec 8, 2012 | 03:47 PM
  #52
aofarrell2's Avatar
aofarrell2
Sorry but you can ruin the mainshaft that way... And it's really hard to get the surface clean enough to make a good strong weld... Then the nightmare for the person dissasembling it later...
Old Dec 8, 2012 | 07:35 PM
  #53
RhinoForPresident's Avatar
RhinoForPresident
Hey - what bell housing are you going to use to connect the NV4500 to the 5.9??
I'm doing the same thing with my ram 2500
Old Dec 8, 2012 | 10:00 PM
  #54
aofarrell2's Avatar
aofarrell2
For gasoline engines 5.9L or below, use the "Gasoline" style bellhousing. IDK if the V10s use a different gasoline one or not, I think they use one SIMILAR to the diesel but not exactly. The diesel uses its own bellhousing.
So I used the "Gasoline" bellhousing, since mine was the 5.9L V8.
Old Dec 9, 2012 | 12:19 AM
  #55
Wombat Ranger
You would have to be a pretty sh1tty welder to ruin a mainshaft welding a nut to a gear. It's as simple as a spot weld, and it's not hard to get it clean at all.
If you needed to dissemble it later for any reason, all you would need to do is grind through a single spot weld. Simple stuff...
V10's and Cummins use the exact same bellhousing. V8's have a different bolt pattern. Just make sure it's a V8 BH and you are good.
Old Dec 9, 2012 | 12:47 AM
  #56
Wh1t3NuKle's Avatar
Wh1t3NuKle
But....but....there are way more sh1tty welders than otherwise. I have read elsewhere of someone welding it and it broke. It being able to break implies a cold weld, yet visually it passed as a "spot weld". However, a spot weld is a through wall weld.
I'm not downplaying that welding is a bad choice, but care is needed for it if that is the option.
Old Dec 9, 2012 | 12:53 AM
  #57
Wombat Ranger
^^^ So basically, if you are a sh!tty welder, don't pick up the damn torch!
Old Dec 9, 2012 | 07:00 PM
  #58
Moochoff's Avatar
Moochoff
Ah man, I remembered how annoyed I was when I had to jack the truck up to slide the 47rh under the frame...
Keep the pics coming....
Old Dec 10, 2012 | 09:52 AM
  #59
aofarrell2's Avatar
aofarrell2
Sure will.... Too cold to do much other than run the torch and cut the old u-joints out today... Got to work on my computers some today. Tomorrow is sposed to be warmer.
Old Dec 10, 2012 | 10:04 AM
  #60
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Buy a heater and get out there!
