2000 RPM idle, on its own
Old Oct 20, 2012 | 08:24 AM
Halojm's Avatar
Halojm
Default 2000 RPM idle, on its own
So this morning I started the truck to run some errands, the Idle shot up to 2000 RPM's on its own. It is somewhat chilly this morning @ 45degrees out. Tried kicking down the idle by tapping the gas with no luck. Shut the truck off and restarted it, same thing 2000 RPM. Let it run like that for 10 minutes, still nothing. Odd. Recent replacements, TPS, IAC, cleaned TB. Everything was fine after all those replacements, any suggestions as to why its doing this suddenly.
Old Oct 20, 2012 | 08:43 AM
gertie240's Avatar
gertie240
pull the iac and check it. sounds like its stuck
Old Oct 20, 2012 | 09:24 AM
Halojm's Avatar
Halojm
Pulled, IAC, still looks new, plunger moves in and out. Put back in, still high idle. I disconnected battery for 5 min. Reset PCM, started, idles fine again. Still doesn't answer question as to the problem. If a week from now it does it again.
Old Oct 20, 2012 | 09:28 AM
Arde's Avatar
Arde
It's a Dodge LOL.
Old Oct 20, 2012 | 09:33 AM
Halojm's Avatar
Halojm
Originally Posted by Arde
It's a Dodge LOL.
True, as soon as she's running the best ever......something pops up. Lol
Old Oct 20, 2012 | 01:55 PM
aofarrell2's Avatar
aofarrell2
Yup. It's a Dodge. In my case it idles around 250-350 RPM normally LOL wish it would idle around 575.
Old Oct 20, 2012 | 02:17 PM
merc225hp's Avatar
merc225hp
Wrong thread post Sorry.
Old Oct 20, 2012 | 05:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Umm, the problem is the IAC. Did you clean it and the TB port? https://dodgeforum.com/forum/dodge-r...n-the-iac.html
And just so you know, cleaning the IAC does not mean it works. You still may need a new one. But the TB still needs to be cleaned before installing a new IAC. And disconnect the negative battery cable BEFORE doing so. And even for cleaning for that matter.
Old Oct 20, 2012 | 05:27 PM
aofarrell2's Avatar
aofarrell2
Just replace the IAC... It is only $20...
