Abs and brake light are on
Old Oct 21, 2012 | 04:08 PM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by h3lzsn1p3r
did you reset the porpotioning valve assuming the line blew out on you just had that on my 98 2 weeks a go
If that switch were closed, the light would be on all the time, so that's not the source of his problem.
Old Oct 21, 2012 | 06:23 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
not true i blew both a front and rear line at once and the light would go off as normal then come back on a few seconds later
Old Oct 21, 2012 | 06:26 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
Originally Posted by zman17
You might want to add how to do that.
yea sorry lol there is a little nut sort of thing on the top of the popotioning valve wiht a brass comperssable sensor have some one put breaks on and push brass pin thing down it should center the valves shuttle sensor inside it
