intermitten wiper speed
Old Oct 25, 2012 | 06:15 PM
peshewa's Avatar
peshewa
Default intermitten wiper speed
I have a 2001 Ram V6. The intermittent wipers work, but no matter where I set it at the intermittent speed is the same. The low & high thing still works great. Any ideas if I need to replace the switch or is it something else?
Old Oct 25, 2012 | 07:19 PM
40intrepid's Avatar
40intrepid
Probably the multi-function switch in the column.
You can buy one at the dealer, or autozone, and install it youreself.
It's not too hard.
Old Oct 26, 2012 | 02:25 AM
dhvaughan's Avatar
dhvaughan
you likely have no power on end of dash fuse (maybe 9 or 13 labeled power windows or power locks). it sends power to the CTM which controls intermittent wiper timing. without that fuse, they wiper delay is at the fastest setting, which is a pulse about every 1 second.
i went through hell on that one and there's some long drawn out troubleshooting posts on it. cut straight to the chase - check/replace those fuses, even if you don't have power windows and power locks.
