Stuck wheel
Old Nov 2, 2012 | 11:07 AM
  #21
Wombat Ranger's Avatar
Wombat Ranger
^^^ You're lucky it only snapped one off.
Old Nov 2, 2012 | 12:16 PM
  #22
Arde's Avatar
Arde
Honestly now, you guys actually use a torque wrench on your lug nuts? Carry one to change a flat with? I've never seen or heard of anyone doing so. I've never done it, and haven't ever had a problem with lug nuts not torqued to some spec.
Old Nov 2, 2012 | 02:08 PM
  #23
jpsycoboy5's Avatar
jpsycoboy5
That's true I think it's more for people that zip them on with a 900ftlb impact gun and wonder why they're breaking studs stripped lugs etc I think the average guy with a wrench can't over do it that much unless you're going Arnold on them and wrenching them on with a 3 foot breaker bar haha
Old Nov 2, 2012 | 02:17 PM
  #24
Gary-L's Avatar
Gary-L
Veteran: Navy
If I have to change a wheel when away from home, I will tighten the lugnuts as much as I can. Once I'm home, I will torque the lugnuts to the proper specifications.
The specs are there for a reason.
Old Nov 2, 2012 | 02:52 PM
  #25
zman17's Avatar
zman17
Retired Moderator - RIP
Exactly.... Not to mention, over tightening can ruin an aluminum wheel. And always check them again after about 20 miles or so.
Old Nov 2, 2012 | 03:34 PM
  #26
QuadCabLuv's Avatar
QuadCabLuv
I just use a torque stick with my impact gun
Old Nov 3, 2012 | 12:32 PM
  #27
NCC74656's Avatar
NCC74656
i carry an air compressor, impacts, and a torque wrench in my bed tool box. ive gotten some funny looks by those first responders on the highway when im out with a floor jack, set of work lights, creeper, impact guns, and torque wrenches on teh side of the highway. lol
Old Nov 3, 2012 | 06:38 PM
  #28
Sheriff420's Avatar
Sheriff420
A girl in my shop class in high school was having an issue getting a getting a steel wheel off and called me over to help. I looked at it to make sure the lugs were all off, they were. I lowered the car (it was on one of those two post lift deals) and kicked the tire on the outer edge near the tread. The tire popped off with just one kick, problem solved.
If I was dealing with a stubborn rim I would have put the lugs on loose enough that the wheel would have a bit of jiggle to it then I would put the weight of the truck on it and give the truck a side to side shake. I would just turn the wheels back and forth if it were a front tire. I don't see the wheel not popping loose doing it that way.
I wouldn't mess with a hammer because rubber bounces, that would be fun story to tell about how you got that bruise on your leg or how you broke your knee cap. I wouldn't want to hit the rim or hub with it either.
If it remains stubborn then CRC Knock'er loose, CRC Freezeoff, Aerokroil (Kroil oil) or Cyclo Breakaway are all good penetrating fluids. PB Blaster, Liquid wrench and WD 40 are lubricants/water displacers, not penetrating fluids.
Old Nov 3, 2012 | 08:54 PM
  #29
gertie240's Avatar
gertie240
I agree , the weight of the vehicle plus a side way motion will be easier and safer then driving it.
Old Nov 4, 2012 | 11:51 AM
  #30
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by oxymoron29
Think about it, you're lubricating the threads and seating surface of the lug, reducing the coefficient of friction as you're tightening it down. The lug will be tighter than the unlubricated equivalent at any given torque rating. Thus, you reduce the torque setting when using anti-seize on lug nuts from factory (dry) spec.
Absolutely correct with respect to what lube on threads effects on torque.
Agreed. Especially the last note about specs. When on the trail, you'd be surprised how many do bring a torque wrench. Doesn't really differentiate so much from average street driving. We have trucks to haul shiz!
Agreed with this approach. I completely envisioned the OP and the Tire Shop reporting some flying hammer... HAHHAHAHA
