Ram won't start
Old Oct 29, 2012 | 02:44 PM
crpunt618's Avatar
crpunt618
Well I hope not, that tanks going to weigh a ton if I cant syphon. Your one of the few lucky ones. That's quite the storm moving up the coast. At least with all the trees down you could have lots of wood for winter.
Old Oct 29, 2012 | 02:57 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Not so, I have no wood stove or fireplace for that matter. That's why I have a generator.
Anyway, get some 3/8" fuel hose and stick it down the fill tube and twist it so it's the fuel. If you can't get it that way. remove the filler neck(which you have to do anyway) and get it out from there.
Old Oct 29, 2012 | 11:13 PM
dlallen66's Avatar
dlallen66
I siphoned 15 gallons out of mine before we dropped it.
Old Oct 30, 2012 | 05:02 PM
crpunt618's Avatar
crpunt618
Thanks all, got the tank almost dry and it came out and installed with ease. New pump sounds a lot healthier.
So what do you all think of the oil in my plenum plate? I replaced with the hughes plenum plate about a year ago and torqued everything properly. I replaced the pcv valve.
Old Oct 31, 2012 | 02:03 PM
zman17's Avatar
zman17
Did you replace the pcv with a mopar from the dealer?
Old Oct 31, 2012 | 10:29 PM
crpunt618's Avatar
crpunt618
No, just the local parts store. Whats the difference? If I need it to prevent more oil i'll go get one.
Old Oct 31, 2012 | 11:00 PM
UnregisteredUser's Avatar
UnregisteredUser
The auto parts store valves are hit and miss, more often miss. They tend to allow too much air flow under high vacuum conditions, which sucks oil into the intake.
Old Nov 1, 2012 | 09:12 AM
crpunt618's Avatar
crpunt618
Interesting. I always try to avoid the dealer because of prices but I'll head there today and pick up a valve.. Is there anything I can do about the oil already there or just leave it?
Old Nov 1, 2012 | 01:50 PM
zman17's Avatar
zman17
Seafoam or leave it. If no more oil get's in it will eventually disappear.
Old Nov 3, 2012 | 02:18 PM
Connie Rowlands's Avatar
Connie Rowlands
I own a 1995 Dodge Ram 1500 I have no spark. Changed Pick-up Coil 2x, Ignition Coil 2x,and order a used Computor form Ebay and Had a Electrical mechcanic check out the wire system. Thought we had it fixed.Ran for a mile and Quit again. Cleaning the Spark plugs now as they have alot of oil & gas smell them and they are Black. Any suggestion to help Thanks My Email: zzlegs36@comcast.net
