Swooshing sounds?????
Old Oct 27, 2012 | 06:17 PM
Randy Curran's Avatar
Randy Curran
Default Swooshing sounds?????
OK so it's running pretty good(even with no o2's!). But when I start it up for the first time I get this swooshing sound. Runs fine but it's weird.
The only thing I can think of is the air filter housing has a small break right where it meets the throttle body.
Anybody?
Old Oct 27, 2012 | 06:28 PM
Sooper's Avatar
Sooper
Possibly the TPS, or throttle position sensor.
Old Oct 27, 2012 | 07:08 PM
Randy Curran
It only does it at startup. Then the more I drive it goes away.
Old Oct 27, 2012 | 07:18 PM
I wouldn't worry about it if there are no driveability problems
Old Oct 27, 2012 | 07:21 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Mine's noisy when cold too.
Even worse if I haven't driven in it a few days after rain or cool weather.
Old Oct 28, 2012 | 12:52 AM
MarkM32's Avatar
MarkM32
Is this like a high pitch noise or low sucking noise. I know my intake loves to make noise when I start my truck.
Old Oct 28, 2012 | 10:26 AM
Randy Curran
It's more lower sounding. Like I said my air filter housing is cracked on the bottom and it doesn't have a gasket either.
Old Oct 28, 2012 | 11:25 AM
stewie01's Avatar
stewie01
Need to get that gasket. If it's not cracked too bad you can probably repair it.
Old Oct 28, 2012 | 12:47 PM
dhvaughan's Avatar
dhvaughan
hissing and swooshing is sort of normal sounds for fast/cold idle. its the large volume of air going through the IAC port.
Old Oct 28, 2012 | 12:55 PM
merc225hp's Avatar
merc225hp
Any chance its the fan clutch? have you checked it? It moves a lot of air and makes lots of noise.
