Front axle shaft seal/ carrier question
Old Oct 28, 2012 | 04:40 PM
BIGRED97's Avatar
BIGRED97
Default Front axle shaft seal/ carrier question
I am in the midst of replacing my axle shaft seals and rebuilding my front axle. Well it is actually a spare front axle i have had laying around/trying to sell but the time has come and my truck needs it. Once I was finally able to remove everything i began cleaning an inspecting and i found that an orange o-ring on the passenger side of the diff where the carrier bearing meets the axle tube appears to be torn up.
Here are a few pictures of what i am talking about, click on the link it is my dropbox, pictures should come up automatically.
http://db.tt/GuX4cAxd
http://db.tt/FcDUKwiy
so my question is, should i be concerned about this? and what can i do to remedy this. Since that is not the seal i am replacing, and it doesn't appears that is a seal i can replace.
Thanks Guys.
Old Oct 28, 2012 | 05:47 PM
dhvaughan's Avatar
dhvaughan
i think that's the sealant from where the axles tubes are pressed/welded/whatever into the diff housing.
so no, no concern.
Old Oct 28, 2012 | 06:19 PM
BIGRED97's Avatar
BIGRED97
awesome, that was kinda my thought. but didn't wanna get all back together and have an issue. I may have done that when pulling the carrier gear. It was a real PITA to get it out.
thanks DH
Old Oct 30, 2012 | 04:22 PM
BIGRED97's Avatar
BIGRED97
Default lower ball joint help
ran into a problem installing my ne4w ball joints. the lower ball joint wont allow me to tighten the nut. the hole shaft inside ball joint just spins. i cant loosen it or tighten it. any advice on what to do? is the new ball joint bad?
Old Oct 30, 2012 | 08:05 PM
AtomicDog's Avatar
AtomicDog
Place a jack under that lower ball joint and jack it up to put some weight on the joint to wedge it into the knuckle. This should be enough force on the lower ball joint to allow the stud not to turn and allow you to tighten the nut on that lower ball joint. Just rebuilt my front end and ran into the same issue
Old Oct 30, 2012 | 08:40 PM
BIGRED97's Avatar
BIGRED97
thanks, i will have to try that in the morning. sounds like it could i just don't want to damage the new ball joint
Old Oct 30, 2012 | 10:15 PM
dhvaughan's Avatar
dhvaughan
they tend to spin when you are using hand tools. if you have an impact, you can hit it with that and it'll tighten up. otherwise, just put a little pressure on it as said. it won't hurt it.
