Tuners, license plate socket, etc.
Old Oct 29, 2012 | 10:39 PM
RareColorRam1995's Avatar
RareColorRam1995
Default Tuners, license plate socket, etc.
Hello all, first off, I'd like to hear some opinions on different tuners available for the gas burners. I have an '01 with a 5.9. I know SCT is the favored tuner around this forum, but I have a gut feeling that it can't adjust the speedometer to accommodate for my 35's. Any in-depth info and pricing is appreciated! Second, my license plate light will not go into the socket, it's either corroded or broken. The wire just hangs down with the bulb sitting in it. Any place I can obtain a replacement? or perhaps someone knows a fix. Any info on this is also appreciated. Lastly, I've heard you cannot use a throttle body spacer with a CAI. Is this true? Thank you for any input.
Old Oct 29, 2012 | 10:46 PM
stewie01's Avatar
stewie01
Better question is why would you want to? Throttle body spacer on these multiport fuel injection motors is useless. A paper weight.
And a expensive CAI Kit is almost useless too, most of them draw air from the same location as the stock air cleaner.
Old Oct 29, 2012 | 10:54 PM
RareColorRam1995
Never said I wanted one. Simply asking if they worked with CAI's.
Old Oct 29, 2012 | 11:28 PM
UnregisteredUser's Avatar
UnregisteredUser
But they do reduce pumping loss as compared to the stock air box, so there's some benefit to be had by stuffing a big fat pipe and a less restrictive air filter on there.
Old Oct 29, 2012 | 11:31 PM
oxymoron29's Avatar
oxymoron29
For the license plate lights you need these:
Amazon Amazon
( Mopar part # 5179988AB )
I think Dorman also makes em, I needed 2 a couple months ago. Just got em at the local parts store.
Old Oct 30, 2012 | 12:14 AM
kejobe's Avatar
kejobe
The light socket is one piece. To replace the bulbs, you need to remove the two screws and the lens. If the socket was pulled from the backside, the socket is now broke. I got a new set off ebay.
For the tuner, SCT fron Hemifever is reguarded as the best here, but you cannot adjust for tire size. You can with (I think) Superchips.
Old Oct 30, 2012 | 07:09 PM
RareColorRam1995
Well that's disappointing about the SCT not being able to adjust for tires. Thank you for the input on the license plate lights, I'll be ordering my replacements today!
Old Oct 30, 2012 | 07:10 PM
RareColorRam1995
http://www.amazon.com/1994-2001-DODG.../dp/B004G4H6M6
What parts store? I work at AutoZone and couldn't find them there.
Old Oct 30, 2012 | 07:25 PM
oxymoron29's Avatar
oxymoron29
I live in Canada so it wouldn't be much help. Call around.
Old Oct 31, 2012 | 12:55 PM
LoneWolfArcher's Avatar
LoneWolfArcher
I got to at O'Reilly's. The plug was different, I just spliced the old connector onto the new sockets and called it a day.
