p0108
Old Nov 1, 2012 | 08:12 AM
Z.rawk95's Avatar
Z.rawk95
Okay, the cat was gutted a month or so ago, apparently it was clogged even though I saw no symptoms, just did distr. cap rotor and plug wires and autolite 3923s about 2 months ago, at first our mechanic told us replacing the pcm would take care of our problem, so we got a reman unit from solopcms, and 02s were replaced about 6 months ago. I got the 02 codes (apparently there were 3) p0131 p0132 p0138.
Old Nov 1, 2012 | 08:23 AM
gertie240's Avatar
gertie240
As far as o2, some trucks only like the NGK type, and alot of people forget about the cam sensor in the distributer. Thats a couple things to think about.
Old Nov 6, 2012 | 08:04 AM
Z.rawk95's Avatar
Z.rawk95
Yesterday I finished with the plenum and when I cranked it up to check for leaks it idled perfect and there was no CEL, gonna take it for a test drive today and make sure everything is running properly.
Old Nov 6, 2012 | 10:49 AM
It's Me Patt's Avatar
It's Me Patt
P0108= MAP sensor voltage too high, or above max acceptable voltage
Old Nov 6, 2012 | 03:10 PM
Z.rawk95's Avatar
Z.rawk95
We've already established this, read my OP
Old May 30, 2013 | 12:01 AM
jetb's Avatar
jetb
K. Here's the scoop! P0108: P1297: P0132: Checked the MAP sensor, checked out good. Switched out the PCM and I get a p0133! New crankshaft sensor, new inductive pick up, new coil, new O2 sensors, and new plugs! Truck runns like a donkey with two broken legs!! I get miss firing, rpm drops off to nothing, exhaust stinks, . It's intermittent! Anybody have any ideas on this one?? I'm running outa things to check!! I cleared the codes, they haven't come back butthe truck is still acting the same!!
