Clutch is letting go advice?
Old Oct 30, 2012 | 09:09 PM
Bobby9498's Avatar
Bobby9498
Default Clutch is letting go advice?
Ok so just got a couple questions, first anyone have any recommendations on an aftermarket clutch kit? Second stupid question I know but does the kit come with a new release bearing? One more question, I've had people tell me I do not new to machine the flywheel instead just buff out the scratches and clean it up return is to smooth again?
Old Oct 30, 2012 | 09:15 PM
UnregisteredUser's Avatar
UnregisteredUser
Get the flywheel turned. While you're in there, do the throwout bearing and the freeze plugs that are hidden by the bell housing.
They make clutch kits? Wow. I didn't know that. I always buy the pieces separately.
Old Oct 30, 2012 | 09:51 PM
Hahns5.2's Avatar
Hahns5.2
I've done plenty of clutches without resurfacing the flywheel. I only did it last time because I expect it to hold a lot of power and there was coolant present in the bellhousing from a leaking freeze plug. A clutch kit should come with the throwout bearing, clutch disk, pressure plate, pilot bearing and alignment tool. I like Valeo clutches.
Old Oct 31, 2012 | 07:15 AM
Bobby9498's Avatar
Bobby9498
Ok one more question, where do you guys prefer to buy them online? Cause for an oe replacement found a couple online for 200 vs nap as $400
