Front U-Joints
Old Nov 2, 2012 | 08:53 AM
Annihilator_X9's Avatar
Annihilator_X9
Default Front U-Joints
Is there any way to changed the front Us out without pulling the axle? I'm thinking not but thought somebody might have a trick up their sleeve.
Old Nov 2, 2012 | 12:22 PM
Arde's Avatar
Arde
No. For drivers side, you also have to pull the differential.
Great engineering.
Old Nov 2, 2012 | 01:07 PM
Annihilator_X9
Damn, what a pain.
Old Nov 2, 2012 | 01:24 PM
dodgetrucker75's Avatar
dodgetrucker75
Great engineering.
what??? you must be talking about changing the seals?
its not that bad fo a job with the right tools, as long as the bearings come out some what easy... pull the calipers, hub nut, unbolt/remove the bearing assembly and the shafts slide out
i found the best way to remove the joints is to just simply torch out the center then punch the caps out, other wise you risk bending/distorting the shafts with a press or beating on them, then clean up and reinstall, just be carefull not to damage the seals when installing the shafts, its also a good idea to make sure there isnt too much crud in the housing so you dont push it into the diff or cad
Old Nov 2, 2012 | 02:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1... I'm thinking someone is confused.
Old Nov 2, 2012 | 09:00 PM
Arde's Avatar
Arde
Confused I was. Just went through the seal thing and had it on my mind.
