Oil pump changed, now wont start
Old Nov 4, 2012 | 05:00 PM
DMMCT5's Avatar
DMMCT5
Default Oil pump changed, now wont start
I have a 97 dodge Ram 5.2 andoil pump quit, so pressure would drop and truck would shut down. So i put in new oil pump and pickup tube. Now it wont start. Help. Please.
Thanks Mike
Old Nov 4, 2012 | 05:18 PM
dhvaughan's Avatar
dhvaughan
did you remove the starter to drop the oil pan.
is the starter plugged back up, elec connector and big wire?
battery connected?
does the starter turn?
Old Nov 4, 2012 | 05:21 PM
DMMCT5's Avatar
DMMCT5
Turns over wont fire.
UnregisteredUser's Avatar
UnregisteredUser
Welcome to DF.
Go back over everything you touched and find the thing you didn't put back where it belongs, or broke in the process.
Last edited by UnregisteredUser; Nov 4, 2012 at 05:21 PM. Reason: dvaughan is faster on the draw than I am!
Old Nov 4, 2012 | 06:35 PM
DMMCT5's Avatar
DMMCT5
I didn't have to take out starter, and did not unhook anything. Just took out oil pan, replaced pump and pickup tube. Replaced oil pan gasket and replaced pan. Now it turnes over but does not fire. I cant find anything i broke.
Mike
Old Nov 4, 2012 | 06:47 PM
dhvaughan's Avatar
dhvaughan
does your 97 have the fuel pressure test port on the rail. check pressure and/or listen for fuel pump whine when ignition is turned on.
shade tree method for testing fuel pressure. put out cigarette. place rag over fuel pressure test port and press the little valve stem. high pressure gas will squirt out. catch in rag and clean up. avoid fire....
check for spark at the plugs.
check for 12v at the coil.
