does limited slip only work when going forward ?
Old Sep 4, 2005 | 05:32 PM
garpoonga's Avatar
garpoonga
Default does limited slip only work when going forward ?
This might seem like a stupiud question, but yesterday I got somewhat stuck, I tried to back out and only the Right rear tire spun, once I went forward both spun, I ****ed into 4x and ended up backing out but found myself asking why only one tire spun when I was in reverse.
Can someone give me a brief education on limited slip diff's.
As per the Dodge spec sheet, the dealer tells me I most definatly have limited slip although they call it an anti spin rear differential
Thanks,
Old Sep 4, 2005 | 08:54 PM
zeekxxx's Avatar
zeekxxx
Default RE: does limited slip only work when going forward ?
Hmmmm I would think it would work the same in both directions. Not 100% sure. Might have to find some mud and try this myself....
Old Sep 5, 2005 | 08:30 PM
Mopar528's Avatar
Mopar528
Mine works in reverse. Keep in mind that a limited slip is not a locker. So if one tire is getting a lot of traction, and one is getting very little traction, the tire with very little traction is going to spin, while the tire that is getting a lot of traction sits still.
Old Sep 8, 2005 | 02:35 PM
garpoonga's Avatar
garpoonga
Thanks for the reply, that makes sense as one tire might as well have been on ice. I should have tried putting on the brake a bit and seen if that helped ??? Do you think it would have ?
Old Sep 8, 2005 | 04:38 PM
Silver_Dodge's Avatar
Silver_Dodge
ORIGINAL: Mopar528
Wait, i'm confused. How is that different then the way an open differential behaves when one tire has traction, and one doesn't?
Old Sep 8, 2005 | 05:03 PM
garpoonga's Avatar
garpoonga
Hence my question on a brief education. I was sure that I knew how these things worked, but I guess not.
duh !!![sm=dontgetit.gif]
