1996 Ram 1500 Rough idle
Old Nov 5, 2012 | 04:49 PM
Eric Eidenberger's Avatar
Eric Eidenberger
Default 1996 Ram 1500 Rough idle
My ram started to idle badly just about a week ago. Sometimes it will idle fine after starting and sometimes it won't. Could this be a CPS? I don't think its the IAC but let me know what you think.
Old Nov 5, 2012 | 04:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Try cleaning the IAC for the hell of it , and disconnect the negative battery cable before doing so. https://dodgeforum.com/forum/dodge-r...n-the-iac.html
Old Nov 5, 2012 | 11:04 PM
Eric Eidenberger
Thank you I will defiantly give this a try.
Old Nov 19, 2012 | 10:13 PM
bigfish2012's Avatar
bigfish2012
did this fix your problem ?
i have the same situation and was going to clean the IAC and then replace both O2S sensors. please let me know
Old Nov 20, 2012 | 12:34 AM
ReadRam's Avatar
ReadRam
Guessing it did, never heard back from him. At least cleaning the IAC part. The throttle position sensor can cause short intervals of rpm surges also...but would drop back to normal idle, at least that's what mine did on it's way out. Welcome to DF! Reply back with results.
