yet more lift questions
Old Nov 7, 2012 | 01:15 AM
cutthroatxxx's Avatar
cutthroatxxx
Default yet more lift questions
What's the best way to gain a few more inches...price was..I have a 2.5 leveling kit& a 3 inch body lift.I thought about doing some 2500 coils or bigger front spacers &some blocks in the back.But I know it can't be that simple...Im guessing Im gonna need some longer brake lines &control arms idk is there anything I can get away with...also is it just an optical illusion or what but single cabs always seem to look like they sit higher then club cabs with the same lift&tires.Also is there any good pic threads for our trucks lifted?
Old Nov 7, 2012 | 02:12 AM
Matt Nickerson's Avatar
Matt Nickerson
Anything you would need to know about lifts has been discussed on pavementsucks...and here on DF.
Can't go over 3 inches of suspension lift without longer trackbar/bracket, control arms, sway bar links/bracket, different pitman arm, and shocks. Brake line brackets may need to be relocated, don't need longer ones until after 7 or so inches.
For the front 2500 coils and the spacer will give you approx 5in of lift. Can't remember if anyone makes 5in blocks for the rear...id recommend keeping your oem 3" blocks there and adding a 2" add a leaf. And again you'll need those components above, they can be found on any site that sells suspension parts and lifts and whatnot.
Reg cabs sit higher because of the lighter weight of the cab.
Old Nov 7, 2012 | 02:17 AM
cutthroatxxx
Thanks that makes sense about the cab being lighter!Never thougt about that
Old Nov 7, 2012 | 08:19 AM
dipsherry's Avatar
dipsherry
get arms from a 2500 they are longer and cheap upgrade pitman arm i got a few drop ones p/m me i will help you out. Track bar if you have oem needs to be upgraded anyways...my g/f has a 01 ore with only spacers and 3" body her truck has 38x15.5x18 with no issues other than we had to do a little bummper trimming with spacers.....but it tows my rig no problem
Old Nov 8, 2012 | 01:04 AM
cutthroatxxx
Just had a new track bar put on yesterday!Haha Im always a day late.,Ill go send that pm
