Clicking noise under dash
Recently replaced the battery post connector on neg side, kept loosening up and would get nothing when turned key to start. Now the replacement is loose and can't tighten to post. Put a vise grip on it until have time to fix, but still was nothing when turned key to start. Radio was on ,but static sounding and power outlet was working. Then I heard this clicking coming from over by fuse panel area, inside the cab. The clicking stopped after 20 seconds... I turned the key and it fired right up. Heard it couple other times over last year. I read clicking noise threads last night until my eyes were bleeding. It's not the solenoid click when your battery is dead. I do have a ten year old astro start that's wired up in that general area. Got it off now. One thread mentioned central control timer? Any enlightenment appreciated
ctm (central timing module). i don't know of any reason for it to click. i'm not sure about the 99, but the 00-01 is a black box about 4 x 2 x 1 behind the power outlet area, attached to the dash brace. on the 01 it contains the dinger/chimer, but otherwise, its just a circuit board in a plastic box.
if your battery cable wont tighten down on the post, buy a new batter cable end at any parts store for about $5 or less. cut the old one off with no loss of wire length and clamp the new one on. it'll have a screw down clamp.
something like this
http://shop.advanceautoparts.com/web...ttery+terminal
something like this
something like this
something like this
