engine trouble limited income cant afford to repair wife battling cancer
Old Nov 11, 2012 | 12:22 PM
merc225hp's Avatar
merc225hp
If this was my truck I would start by doing a comp test on all the cylds, dry and wet tests should be done. Post back the numbers, don't matter if it was done three weeks ago do it again please.
Old Nov 12, 2012 | 12:22 AM
laharve5's Avatar
laharve5
So it wouldn't throw a code? I've never done a compression test before. Ill have to find someone who is more mechanically inclined than myself.
Old Nov 12, 2012 | 12:43 AM
merc225hp's Avatar
merc225hp
The comp testing tool is $40. It's not hard to do, info on how to do it might come with the tool or just a search on the web and you will find the info. If you can remove the spark-plugs you can do this test yourself.
Old Nov 13, 2012 | 10:35 AM
laharve5's Avatar
laharve5
I'm having a friend check this week or next. Thanks for the input. Do you know if a bad steering shaft will affect my alignment. My alignments off my passengers side front right axel started leaking and the shaft is loose. I'm at 200k. Can I get alignment with replacing steering shaft it has like maybe 1/4" play the most. The shaft is like 3 bills too much.
Old Nov 14, 2012 | 12:47 PM
It's Me Patt's Avatar
It's Me Patt
getting an alignment won't be effected by play in the shaft, but I'd fix the axle 1st..I have play as well but it still is good as far as the alignment goes
Old Nov 14, 2012 | 02:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Anyone with a limited income should not own a Ram. And they will not be able to buy or rent test equipment for that matter. The only choice to try and save money is to go to the local U Pull It.
Old Nov 15, 2012 | 12:14 AM
laharve5's Avatar
laharve5
The limited income is only for a few more months. My wife is on her last round of chemotherapy. For those who offered their expertise, thank much so much. I believe ill finally be able to get it fixed the right way this time. And for those with their 2 cents, well you know where it belongs.
Old Nov 15, 2012 | 10:43 AM
It's Me Patt
Do as you will, but trust me when I say nothing was directed at you. It's just seems or is that our trucks are money pits..such as mine. Good thoughts and best wishes to you and your wife!!
Old Nov 15, 2012 | 10:46 AM
It's Me Patt
Hey Merc so it's your truck that's on the other side of the rainbow? Kinda figured it would be a ram
Old Nov 15, 2012 | 04:10 PM
zman17's Avatar
zman17
Maybe you should have stated that to begin with. I have one less foot due to cancer, so I know all about that.
And as, It's Me Patt stated "Do as you will, but trust me when I say nothing was directed at you. It's just seems or is that our trucks are money pits..such as mine. Good thoughts and best wishes to you and your wife!! "
Hence the at the end of my statement. Someone needs to calm down.
