tach and speedo not working !!
Old Nov 13, 2012 | 01:39 PM
db204's Avatar
db204
New Member
Default tach and speedo not working !!
hi i have a 1997 dodge ram, it is a 5.2l and it recently had a tranny swap. automatic to manual. im being told lots of things such as i might need a speedo from a manual to complete the conversion any ideas ?
Old Nov 13, 2012 | 09:34 PM
ryan0714's Avatar
ryan0714
normally when tach and speedo dont work it would be the wheel speed sensor on the rear axle. maybe someone else will chime in
Old Nov 14, 2012 | 09:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
On a 97 I suppose it could be the output speed sensor on the tranny or transfer case too. try this and see if you have any stored codes. http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
