Leaking tranny lines
Old Nov 15, 2012 | 08:40 AM
Meaning install the inlet and outlet so that fluid flows in the direction of the big arrow stamped on the filter housing???
Old Nov 15, 2012 | 11:01 AM
gertie240's Avatar
gertie240
The check valve is the IN side right? I want to delete my check valve but want to do it the right way.
Old Nov 15, 2012 | 08:24 PM
guzman's Avatar
guzman
Default remote filter
Summit Racing has a Hayden 2106 remote filter setup for $35.90 shipped (ebay), it does not come with a filter but I like to choose my own so that was OK. I too want to plumb it the correct way so am watching this post to confirm. Thanks
Old Nov 15, 2012 | 09:10 PM
dhvaughan's Avatar
dhvaughan
when using a remove filter, you get the effect of the check valve built into the filter. its critical that your transmission cooler lines are routed correctly. connect the hot pressure line to the IN port on the filter housing.
fluid can only flow one way through the filter: from IN to OUT. it will not flow from OUT to IN, so if you plumb it backwards, you kill the trans.
if you have any doubt about the flow of the transmission fluid, disconnect the lines and put the ends in a bucket. crank the truck and have a helper shift to neutral for a moment. the AT pump will come on and squirt fluid out the pressure line. LABEL it.
if you want to put in a cooler, here's more pics.
https://dodgeforum.com/forum/2nd-gen...ter-added.html
Old Nov 16, 2012 | 04:58 PM
guzman's Avatar
guzman
Default Remote filter pics
In case anyone is interested in a filter setup that has fittings that are 90 degree rather than straight up here is a setup. It also takes the same filter that the 5.9 gas motor does (not included in kit). More info. in my previous post.
Old Nov 17, 2012 | 01:07 PM
gertie240's Avatar
gertie240
that looks cool, I noticed the input side is on the left, I just got one from Ebay that had 90s already on it but the input is on the right.
Old Feb 20, 2013 | 04:19 PM
joenov's Avatar
joenov
Default same problem
I'm have the same problem with my 2000 Ram 1500. From what I am reading, I can eliminate the check valve completely from the cooling line? What happens when the Torque Converter drains?
Old Feb 20, 2013 | 06:38 PM
guzman's Avatar
guzman
Default Filter
If your fixing leaking lines I highly recomend installing a remote tranny filter on the fenderwell then it will eliminate any worries of torque converter draining. It can be done for under $50 including ATF hose, clamps and filter. You won't be sorry.
