97 ram no spark no fuel help please
Old Nov 18, 2012 | 02:27 PM
ram0325's Avatar
ram0325
Tntech if I have no cel and the bulb is good will a scanner be able to communicate with pcm. When key on allother lights come on briefly except cel
Old Nov 18, 2012 | 05:25 PM
ram0325's Avatar
ram0325
Update guys. No com with cpu and all sensors that should get 5v are only gettin bout 2.4. Makes me think new cpu but this is number 3 now???
Old Nov 18, 2012 | 05:38 PM
UnregisteredUser's Avatar
UnregisteredUser
At that point I'd be grabbing the factory service manual (for reference) and disconnecting sensors one at a time to see if one of them is fubar, also moving wires this way and that to determine if there's a short to ground somewhere pulling that voltage down. Could be the PCM is at fault, but it would suck to replace the thing only to find that the symptom doesn't change because some sensor is failed.
Old Nov 18, 2012 | 06:58 PM
It's Me Patt's Avatar
It's Me Patt
I found your thread and there's your answer bro ^^^(above) and just cause no scan comm with PCM doesn't mean bad PCM
Old Nov 18, 2012 | 08:45 PM
ram0325's Avatar
ram0325
Ill check some more but crank sensor pickup coil coil and cpu are all new. What other sensors would affect it like this. As for wiring I've been checkin like crazy. I heard somethin bout cpu voltage flowing through brake switch and that if the switch is bad it can shut down spark and fuel. Any one heard of this?
Old Nov 18, 2012 | 10:46 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Coolant temp sensor, MAP sensor, Throttle position sensor, Battery temp sensor, Crank sensor, Distributor pickup. The O2 sensors can take the PCM offline too. Just go around unplugging things. Reboot the scan tool and check the communication after every one.
Old Nov 19, 2012 | 08:12 AM
It's Me Patt
call me crazy but shouldn't the neg bat cable be off when working on sensors?
Old Nov 19, 2012 | 11:56 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Yea, but sometime's when troubleshooting you can't.
Old Nov 19, 2012 | 02:30 PM
gertie240's Avatar
gertie240
what about the nuetral safety switch since he did a tranny ? would that make a difference?
Old Nov 19, 2012 | 10:46 PM
ram0325's Avatar
ram0325
No time today will check more tomorrow. Just unplug a sensor and see if scanner says anything different? I appreciate all the help guys. Hopefully it'll be goin soon and well know what the issue is. Anyone have any input on the brake switch question asked in last post?
