Transmission service
Old Nov 19, 2012 | 08:24 PM
jconlin's Avatar
jconlin
Default Transmission service
i am just about to change my fluid in my 46re and im wondering if i should do a band adjustment? truck has 103k on it and im sure this is its first transmission service, if it needs a band adjustment im scared to do it, im 16 years old and dont have the money to be fixing transmission problems, any advice is greatly appreciated.
Old Nov 19, 2012 | 10:33 PM
dhvaughan's Avatar
dhvaughan
if its shifting ok and not slipping, leave them alone.
consider adding a drain plug to make it easier next time.
advance has them for pretty cheap.
http://www.pavementsucks.com/tech-article-39.html
Old Nov 19, 2012 | 10:44 PM
I must be using the wrong words but I cannot find the band adjustment thread....I was going to post it up for him.
Old Nov 20, 2012 | 09:47 AM
dhvaughan's Avatar
dhvaughan
http://dodgeram.org/tech/repair/index.html#xmssn
Old Nov 21, 2012 | 08:27 PM
jconlin's Avatar
jconlin
thanks guys ill take the advice, got the stuff today and i plan on gettin er done on saturday
Old Nov 21, 2012 | 09:51 PM
UnregisteredUser's Avatar
UnregisteredUser
Not to be contrary, but my personal take on the matter is that if you wait until obvious problems manifest themselves, the bands have been slipping for quite a while and will be glazed already when you perform the deferred maintenance.
Old Nov 21, 2012 | 11:13 PM
gdstock's Avatar
gdstock
+1. Adjusting is a process to assure proper clearance. But make sure you do it EXACTLY as described in service manual....torque wrench and all...
Old Nov 22, 2012 | 01:44 AM
jondakotaguy's Avatar
jondakotaguy
Follow the service guideline prescribed by the manufacture. They list them for a reason. If it's time to do it.. get it done. If not; if it's not broke dont fix it.
Old Nov 22, 2012 | 10:48 PM
jconlin's Avatar
jconlin
I think I'm going to hold off this time, I will change it again in about a month because ive read not to have it flushed if it has never been changed before, that will give me time to build up the confidence and get a good torque wrench, right now we just have one from harbor freight that I don't trust, the truck won't be driven much in the next month anyways, thanks though, I have learned so much from this forum ( for future reference for when I do try to do it , 1 foot pound = 12 inch pounds right?)
Old Nov 22, 2012 | 11:45 PM
gdstock's Avatar
gdstock
Get a torque wrench in inch pounds. Low end of range is least accurate.
