A/C pump running
Old Nov 20, 2012 | 06:50 PM
Halojm's Avatar
Halojm
Default A/C pump running
Question, my A/C pump runs, kicks on and off even when I'm not running A/C in the cab. Is this normal, the condenser gets cold as well as the lines under the hood.
Old Nov 20, 2012 | 06:53 PM
kejobe's Avatar
kejobe
It will cycle with the deftost. Normal.
Old Nov 21, 2012 | 02:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1..... Normal.
Old Nov 21, 2012 | 04:12 PM
Check you plenum.
Old Nov 21, 2012 | 04:17 PM
Halojm's Avatar
Halojm
Originally Posted by jkeaton
Check you plenum.
I never noticed it until after I fixed the Plenum, lol glad to hear its normal however, just seems odd for it to run when the heat is on.
Old Nov 21, 2012 | 05:09 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
The A/C runs when in defrost mode to put mositure into the air to help the windows from fogging up. So as everyone else has said yes it is perfectly normal and nothing to worry about.
