Compression Test Results!
Old Nov 21, 2012 | 05:40 PM
Ham Bone's Avatar
Ham Bone
Default Compression Test Results!
Did the ole compression check today, I am both somewhat pleased but also sad at the same time. But it is a 207,000 mile 12 year old truck with a hard worked engine.
Here are the results
1-140
2- 120
3- 130
4- 150
5- 135
6- 130
7- 125
8- 90
Cylinder 8!! What happened!?!?
Well where should I go from here? Is it more likely to be a ring or the condition of the head and the valves?
Ive always wanted some new heads, maybe I just got my justification.
Old Nov 21, 2012 | 06:23 PM
kejobe's Avatar
kejobe
Do a leakdown test to determine what is not sealing.
Old Nov 21, 2012 | 06:37 PM
Ham Bone's Avatar
Ham Bone
Inform of this leak down test good sir
Old Nov 21, 2012 | 06:57 PM
kejobe's Avatar
kejobe
Heres a cheap way of doing it.
http://api.viglink.com/api/click?for...13535421732882
Old Nov 21, 2012 | 07:13 PM
Ham Bone's Avatar
Ham Bone
Originally Posted by kejobe
I can't weld
Old Nov 21, 2012 | 07:34 PM
crazzywolfie's Avatar
crazzywolfie
where is the wet test results? did you do this test with the engine hot and throttle open all the way?
you don't need to be able to weld to do a leak down test but you do need a compressor and a couple of fitting. spark plugs have the same thread count as a 1/4 in. NPT fitting but with the dumb head shields you can't just screw a fitting into the hole. you need an extension.
Old Nov 21, 2012 | 07:51 PM
Ham Bone's Avatar
Ham Bone
I didn't do the wet test. How much of what do I squirt in?
Why does the throttle have to be open?
Oh and welding refered to the link where the guy takes an old spark plug, knocks the porcelain out of it and then welds an air fitting to it.
I don't have a compressor either
Old Nov 21, 2012 | 08:31 PM
crazzywolfie
i know. i have seen that video before. i tried knocking the porcelain out of a spark plug and it never really worked. plus i don't know if you would be able to get a airline on a fitting welded to sparkplug with the heat shield.
a shot or 2 of oil in the cylinder before testing will tell you how bad the rings are. if the rings are bad the oil will cause the compression to jump. i think holding the throttle all the way open allows the engine to suck up as much air as it can and give you more accurate numbers quicker. otherwise it is like sucking air through a straw.
Old Nov 21, 2012 | 09:15 PM
Ham Bone's Avatar
Ham Bone
Ahh I see, will do it again
Old Nov 21, 2012 | 10:41 PM
ReadRam's Avatar
ReadRam
Just curious, were there driveability symptoms that prompted the compression test?
