weird cranking issue
Old Nov 24, 2012 | 05:51 PM
  #21
QuadCabLuv's Avatar
QuadCabLuv
i tried swapping the asd relays with a couple of other ones and nothing. I checked the asd circuit and im getting power to 3 of the 4 connectors for the relay so that should be good. I checked my connections at he PCM and its all good so it has to be the pcm.
Old Nov 24, 2012 | 06:21 PM
  #22
gdstock's Avatar
gdstock
Check schematics. Something else may be the issue. Don't just chunk the PCM.....not yet...
Old Nov 24, 2012 | 06:40 PM
  #23
QuadCabLuv's Avatar
QuadCabLuv
the coil pack appears to get power directly from the ecu. it was firing one sec then nothing.
Old Nov 24, 2012 | 07:21 PM
  #24
aofarrell2's Avatar
aofarrell2
Coil could be weak tho. Is the coil getting power?
Old Nov 24, 2012 | 08:29 PM
  #25
QuadCabLuv's Avatar
QuadCabLuv
After closer review I am slightly confused but I think I am getting closer to a difinite answer.
Old Nov 24, 2012 | 08:34 PM
  #26
aofarrell2's Avatar
aofarrell2
What's the answer you are thinking of?
Old Nov 24, 2012 | 08:56 PM
  #27
QuadCabLuv's Avatar
QuadCabLuv
Coil receives power directly from asd relay and ground from pcm. I will check the asd circuit tomorrow, which receives power directly from battery afte going through a 30amp fuse. Asd also receives power from ignition switch durin run and start. Looks like asd relay only controls fuel pump relay and coil. I am getting power to the fuel pump so the asf circuit must be working.
So to sum it up im not receiving a signal ground from the pcm to fire the coil. I will verify tomorrow.
Old Nov 24, 2012 | 09:03 PM
  #28
QuadCabLuv's Avatar
QuadCabLuv
Old Nov 25, 2012 | 06:26 PM
  #29
QuadCabLuv's Avatar
QuadCabLuv
got it all fixed. shorted wires were to blame. and a faulty dizzy cap. runs like a dream now. too bad i lost the key.
Old Nov 25, 2012 | 08:19 PM
  #30
ReadRam's Avatar
ReadRam
inquiring minds want to know, which wires were shorting?
