engine takes 20 minutes to warm up??
Old Nov 22, 2012 | 08:17 PM
Qaiphyx's Avatar
Qaiphyx
Default engine takes 20 minutes to warm up??
Dodge ram 1500 5.2L. Takes 20 minutes before the temp goes up driving. What's the deal?
Old Nov 22, 2012 | 08:23 PM
gdstock's Avatar
gdstock
Goes up how far? Several factors. How "cold" is it to start? Are you using the highy inaccurate dash gauge to measure temp? What tstat do you have and how old is it?
Old Nov 22, 2012 | 08:29 PM
What year? How many miles? Does it have a t-stat in it? Do you get heat out of the vents or are you just looking at the gauge?
Old Nov 23, 2012 | 12:22 AM
Qaiphyx's Avatar
Qaiphyx
Weather is 19 degrees.
thought it was just the gauge but no heat.
1996, 150,000 miles, not sure on the t-stat
Old Nov 23, 2012 | 08:19 PM
dhvaughan's Avatar
dhvaughan
sounds like a bad t-stat. replace with a nice new Stant Superstat 195*
Old Nov 23, 2012 | 09:04 PM
gdstock's Avatar
gdstock
That's part of the problem! It is too damn cold where you live!
+1 on checking/replacing tstat. I would almost be there isn't one in there!
Old Nov 24, 2012 | 11:55 AM
1997DodgeRam's Avatar
1997DodgeRam
If this is a new to you truck it could be no tstat. After a side of the road removal of a bad tstat I drove for a couple days with out one and never got much past the 130 mark on the bottom of the gauge and never got enough for heat and that was in the 50s or 60s ambient temp if I recall
Old Nov 24, 2012 | 12:14 PM
gertie240's Avatar
gertie240
when you buy that new stat take it into the house first and watch it in a pot of water. it should open completely right before boiling. Its always better to check one before, had to replace it three times, before I started doing that trick.
Old Nov 24, 2012 | 12:33 PM
Echosider's Avatar
Echosider
Low coolant is a possibility when it comes to heat. I have two vehicles (the truck isn't one of them) that lose coolant slowly and I know it's time to refill when the heat goes. I don't get a low coolant light either, but it does show a low temp on the dash gauge. Make sure you have coolant in there first, then definitely thermostat.
