Hazards do not work when button is pressed but turn signals do
Old Nov 25, 2012 | 04:37 PM
M Laborde's Avatar
M Laborde
Smile Hazards do not work when button is pressed but turn signals do
My daughter came to me today & said her turn signals & brake lights weren't working. She actually had reverse lights & the 3rd brake light working but nothing else on the rear. I checked bulbs, new flasher, wiring, etc but everything checked out. I bought a new multi-switch & replaced that & it seemed to work.
But...
Before I bolted the new switch into place I noticed that the hazard light button was pressed & the blinkers worked, not the hazards. I released the hazard button & had the same problem I did with the old switch (no turn signal & no brake lights). I hooked the old switch back up & found that if I pressed/activated the hazard button, I got normal turn signal & brake light operation & not hazards. Releasing the hazard button got me no hazards & no brake lights nor turn signals.
Since there was no functional difference between the new & old switches, I left the old switch in.
Not having hazard lights concerns me but what concerns me more is the fact that brakes & turn signals only work when the hazard button is pressed. The hazards are supposed to be on an unswitched feed.
Has anyone encountered this or have any ideas?
TIA!
Mike
Old Nov 26, 2012 | 07:28 PM
M Laborde's Avatar
M Laborde
No ideas?
Old Nov 27, 2012 | 03:09 PM
Wombat Ranger's Avatar
Wombat Ranger
Checked the obvious? (fuses & relays?)
Old Nov 27, 2012 | 05:20 PM
gertie240's Avatar
gertie240
replace the hazard flasher relay,
