#8 misfire questions
Old Nov 26, 2012 | 07:47 PM
rerogers's Avatar
rerogers
truck
Old Nov 26, 2012 | 07:55 PM
stewie01's Avatar
stewie01
That would be a great time to change the timing chain, go for a Cloyes Double Roller from rockauto.com, also water pumps are cheap, and no better time then now.
Old Nov 26, 2012 | 08:22 PM
Arde's Avatar
Arde
...and thermostat and bypass hose.
Old Nov 27, 2012 | 02:47 AM
ReadRam's Avatar
ReadRam
Also make sure none of your plug wires are up against #8 injector harness wires.
Old Nov 27, 2012 | 08:48 PM
rerogers's Avatar
rerogers
Thank you all for the tips.
Old Nov 27, 2012 | 08:51 PM
jondakotaguy's Avatar
jondakotaguy
Dont forget to decarbon the engine.. clean/polish your intake ports really good if you can as well or let the soak cyl's soak with either Engine Tune by BMP or the actual Chrysler/Dodge Foaming Decarboniser.. follow the directions in the TSB or on the can closly and have your cat checked.
stewie01's Avatar
stewie01
Originally Posted by rerogers
Thank you all for the tips. I made sure I routed all of the plug wires correctly and that did not help. So I removed the throttle body and found a small pool of oil in the back of the intake. I will be ordering the Hughes V8 MAGNUM PLENUM REPAIR KIT soon. Hopefully this will fix my #8 misfire issues. I also read that it is a good idea to replace the O2 sensors as well if I have a bad plenum.
Yup, good time to replace the front O2. Also good time do to something with the catalytic converter as it's most likely clogged.
