WOT runs great other than that runs like poop.
Old Nov 24, 2012 | 02:01 PM
Nighthawk Pyro's Avatar
Nighthawk Pyro
Default WOT runs great other than that runs like poop.
Did the fuel sync, changed coolant temp sensor, wires to tsb, cap, rotor, plugs, crank sensor, plentum gasket, it has 130 comperssion a little low but should run. This is a 95 Ram 1500 5.9 4x4. Could the trans temp sensor cause this had to replace line and I omitted the sensor?
Old Nov 24, 2012 | 02:02 PM
UnregisteredUser's Avatar
UnregisteredUser
Define "runs like poop", please.
Old Nov 24, 2012 | 02:09 PM
Nighthawk Pyro
Okay Low idle, the IAC opens up and seem to be running rich take it out and try to drive it backfires through the intake. try to hold at even speed the the engine looses power starts backfireing throught the intake, stomp it to the floor and it will through you in the back seat and run great untill you try to drive normal.
Old Nov 24, 2012 | 02:31 PM
gdstock's Avatar
gdstock
How is your cat?
Old Nov 24, 2012 | 02:33 PM
Nighthawk Pyro
No cat and exhaust is clear.
Old Nov 24, 2012 | 02:35 PM
gdstock's Avatar
gdstock
How do you kow IAC opens up? Got a scanner hooked to it? Is the IAC port clean?
Don't know about a 95, but a 99 has the temp sensor inside the tranny.
Old Nov 24, 2012 | 03:11 PM
Nighthawk Pyro
You can hear it open up and draw in excessive air.
Old Nov 24, 2012 | 03:12 PM
Nighthawk Pyro
Oh and the temp sensor is on the line just out side the trans case.
Old Nov 24, 2012 | 03:14 PM
Nighthawk Pyro
and yes I cleaned everything out.
Old Nov 24, 2012 | 04:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'm thinking bad IAC.
