2001 Ram 1500 5.2L 4x4 No power at coil
Old Nov 27, 2012 | 06:37 AM
DMA81's Avatar
DMA81
New Member
Default 2001 Ram 1500 5.2L 4x4 No power at coil
I know there are a lot of threads here on this but im just not having any success. My truck has been sitting all summer, i have been starting it from time to time, its been gradually getting harder and harder to start. It stalled 6 or 7 times just getting it in the gar, i did a full tune up, changed cam sensor and crank sensor. I also got my hands on another coil just in case. I have been working on this for 2 days now with no luck, i have no power to the coil but i do have the 12v on the black wire for a coule of seconds when turning the key. I have pulled the neg cable a few times to reset, the last two codes were 0443 and 1282, this is really bugging me, i have done so many test and check up to this point, the only thing i havnt done is unwrap the harness and check every wire, i fixed a few grounds that were corroded. I have power to the asd and if i put in a jumper i can get power to the coil, i hve changed the relay as well. What seems strange to me is that two days ago i thought for sure i had a constant 12v at coil but no signal from pcm wich is opposite what i have now. Any help would be much appreciated!
Old Nov 27, 2012 | 06:55 AM
dhvaughan's Avatar
dhvaughan
i don't know, but here are some very detailed threads for troubleshooting it.
welcome to DF.
https://dodgeforum.com/forum/2nd-gen...r-to-coil.html
https://dodgeforum.com/forum/2nd-gen...ont-start.html
https://dodgeforum.com/forum/2nd-gen...ing-right.html
