Need recomendation on OBD to Laptop tech
Old Nov 27, 2012 | 02:33 PM
johnnyrocket5363's Avatar
johnnyrocket5363
Default Need recomendation on OBD to Laptop tech
I have a relatively high end scan tool, but it is not telling me everything I need to know, primarily O2 sensor info and sensor trends. I was cruising around online, and found a plethora of OBDII to USB adapters and a few programs. Does anyone know much about them? I am the area shade tree mechanic and would need this for nearly everything (Ford, Chevy, Jeep, Toyota). Thanks for the help!!
Old Nov 27, 2012 | 02:38 PM
drewactual's Avatar
drewactual
do you have a smart phone, and if so, what kind?
if it's an android, torque is a free app that will monitor pretty much all the important stuff.. you'll need an ELM327 OBDII to Bluetooth converter to make it happen (amazon, $20)... the only place the thing is disappointing with is air to fuel ratio, BUT, it does give lambda- which is dang near as good..
I've owned MANY devices that do this.. you can't program with anything south of $1k, but you can monitor with a bunch of them.. of all I've used/owned/played with, the torque app is the easiest and less annoying to use..
Old Nov 27, 2012 | 03:43 PM
johnnyrocket5363
No smart phone, just a laptop. I wanna get one that reads everything.
