dodge problem
Old Nov 29, 2012 | 06:10 PM
boowish's Avatar
boowish
Default dodge problem
Got a big problem i have a new battery an alternator is putting out good. My gauge says its low and my speedo is jumping. And every now and then the transmission wont shift out of third and just reeves up please help. Done changed output speed sensor
Old Nov 29, 2012 | 06:11 PM
boowish's Avatar
boowish
Got a big problem i have a new battery an alternator is putting out good. My gauge says its low and my speedo is jumping. And every now and then the transmission wont shift out of third and just reeves up please help. Done changed output speed sensor and checked all my grounds
Old Nov 29, 2012 | 07:00 PM
cruzer55's Avatar
cruzer55
Need a scan tool and see if it's voltage regulator which is in the PCM.Your not the first to have this problem.
Old Nov 29, 2012 | 07:20 PM
boowish's Avatar
boowish
Where can i get the scan tool at
Old Nov 29, 2012 | 08:03 PM
Wombat Ranger's Avatar
Wombat Ranger
You are using this forum, wouldn't that imply that you know how to use the internet?
Old Nov 29, 2012 | 08:37 PM
boowish's Avatar
boowish
Yeah i do but ppl dont usually call them scan tools thats y i said what i did bc last time i checked they was called obd 2 scanners duhhh
Old Nov 29, 2012 | 09:14 PM
First of all, why did you create two threads on the same thing? Second, why did you post a technical question in the general discussion section? Third, scan tool = scanner. Seems pretty simple to me. Take it to autozone. They will scan it for you.
Old Nov 29, 2012 | 09:44 PM
ReadRam's Avatar
ReadRam
The free scan tool at autozone will only read code if CEL is on, won't give you any live data as suggested in post #3 to see what VR is doing. OP Are you saying that your battery is good and alternator is charging , but dash gauge says it's not.? What prompted output speed sensor replace?
