Is this normal?
Old Nov 30, 2012 | 03:51 PM
nskyline34's Avatar
nskyline34
Default Is this normal?
I have a 2001 Ram 1500 with 4.11's and 33's and when I put it in gear an let off the brakes it doesn't move like it should at idle, just sits still, or HARDLY moves. Is this normal or not? If not how can I fix it? Also is there anything in the t-case I can change to get a better crawl ratio?
Old Nov 30, 2012 | 04:16 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Mine does it when it is cold. When the trans has had some fluid run through it it moves better. And i have 3.55's..
Old Nov 30, 2012 | 05:07 PM
Mine sits there until I give it about 50% throttle when cold before it starts moving....
Old Nov 30, 2012 | 07:28 PM
dhvaughan's Avatar
dhvaughan
i think its normal.
torque converter slips until you rev up enough rpm for it to start pulling.
that rpm level varies a lot, based on tc stall speed and condition of tc.
my old worn out stock tc wouldn't move until 1500-1600 rpm.
my new tc starts moving at about 1200-1300.
Old Nov 30, 2012 | 08:16 PM
Moochoff's Avatar
Moochoff
Originally Posted by dhvaughan
i think its normal.
Definitely agree. Stock TCs seem really loose to me
between the engine swap and the diesel/low stall TC the truck lunges in gear kinda hard now
It also idles itself right into 2nd gear and almost 3rd lol
Old Nov 30, 2012 | 10:08 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Let it warm up longer.
You can get a tera low 4:1 kit. You can put 241 parts into the 231.
Old Dec 1, 2012 | 10:21 AM
zman17's Avatar
zman17
Retired Moderator - RIP
If it's at correct idle(650 about) The truck should move when put in gear , no matter how cold. 23 degrees here this morning and when I put my truck in gear I had to push the brake to keep it from rolling. And I even have the check valve deleted. I'd say you might want to adjust the forward band.
Old Dec 2, 2012 | 02:15 PM
nskyline34's Avatar
nskyline34
It does it in reverse too and seems to improve slightly ince warm up not much. How do I go about adjusting the forward band?
Old Dec 2, 2012 | 02:30 PM
zman17's Avatar
zman17
1st and reverse are same band. Download the 2001 service manual in this thread and read up on adjusting the bands. https://dodgeforum.com/forum/2nd-gen...load-test.html
