Transmission slipping issues
Old Dec 1, 2012 | 01:09 PM
ROWDYROB's Avatar
ROWDYROB
Default Transmission slipping issues
Hey---i have a 97 dodge ram ss/t---200,000 miles,tranny has gave issues for a couple of years now as when i would first start up it would not want to shift and would rev way up in everygear before it did---didnt seem to do it after first morning crank up----i recently changed the fluid and filter and now it still does that some but has also started to just not go into gear???---i can be sitting in drive thru and it will be like its in neutral and then catch into gear,other day it did it while driving and just started rpms going up and down as if it was going into neutral and then back into gear several time before it quit and just went into gear----------just wondering if there may be a sensor or something simple that it could be or if it is about rebuild time????----thanks
Old Dec 1, 2012 | 01:36 PM
Nereaga's Avatar
Nereaga
Sounds to me like rebuild time. Start getting quotes
Old Dec 1, 2012 | 01:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1, 200k it's all done. You can waste time and money screwing around with it. But I'd save the money for a rebuild.
Old Dec 1, 2012 | 08:34 PM
ROWDYROB's Avatar
ROWDYROB
yep----kinda my thoughts but just grasping for an easy fix-----about what does this normally run---and i know it will vary from state to state,etc.---thanks
Old Dec 1, 2012 | 08:46 PM
dlyter09's Avatar
dlyter09
Depends on what you want done.. Id personally go for a PATC transmission and not worry about it.. Mega Vipers
Old Dec 1, 2012 | 09:22 PM
QuadCabLuv's Avatar
QuadCabLuv
Cost me $950 and they pulled it and put it back in. Came with a 2 yr 24k warranty too. So shop around. I priced st 6 shops anywhere from 900-1500.
But if I had the money I would much rather have spent it on a mega viper. Which are right around $2500
Old Dec 1, 2012 | 09:28 PM
gdstock's Avatar
gdstock
Well, it does vary....but knowing where you are may allow someone to give you some personal experience...Mine was about $600.
