Rear Diff question....
Old Dec 5, 2012 | 01:19 AM
merc225hp's Avatar
merc225hp
Keeping the fluid clean is a big plus, using a top grade oil helps, make sure you use the slip additive when changing oil or get a oil that has it in it. Not running a bigger tire than say 285/75r16 helps. I have some that I have rebuilt and they are fine like years on them, others did not last so long (months). N drops will kill them in a hurry.
Old Dec 5, 2012 | 01:34 AM
Tampaguy77's Avatar
Tampaguy77
I have 265/75/16's on my truck now..... But do I have to take the whole rear end off the truck... or can the rear diff be rebuilt with the rear end on the truck?
Old Dec 5, 2012 | 01:45 AM
merc225hp's Avatar
merc225hp
The rear end can stay under the truck, just need to pull the axles, carrier, bench work then re-assy, say 4 hrs work. You will need at least one special tool for the side adjusters. Have you found the FSM in the diy area? Have you ever worked on a diff before? this is not for the timid.
It will look like this when tore down.
Old Dec 5, 2012 | 01:49 AM
Tampaguy77's Avatar
Tampaguy77
I have replaced rear axle seals quite a few times.... I am mechanically inclined also. But no I have never rebuilt A rear diff. What is FSM?
Old Dec 5, 2012 | 01:56 AM
merc225hp's Avatar
merc225hp
FSM= Factory Service Manual in the 96 book page 132 or sec 3-66
Found here https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old Dec 5, 2012 | 02:00 AM
Tampaguy77's Avatar
Tampaguy77
Ok Great!! Thanks for the info!!
Old Dec 5, 2012 | 02:14 AM
merc225hp's Avatar
merc225hp
Have fun and post back your findings.
Old Dec 5, 2012 | 02:24 AM
Tampaguy77's Avatar
Tampaguy77
I deff will!! I know this has nothing to do with the Rear Diff.... But any chance do you know what cause my 4x4 indicator light to stay on? The $wd is not engaged and when I do engage the 4wd it works fine. Just curios why the light stays on
Old Dec 5, 2012 | 02:27 AM
merc225hp's Avatar
merc225hp
Most likely the sending unit at the CAD on the front diff, two wire plug.
