DTC code 37?
Old Dec 4, 2012 | 06:53 PM
welder123's Avatar
welder123
Default DTC code 37?
hi today I checked the stored DTC codes on my 1994 1500 5.2L automatic. the codes I got were 12, 37, and 55, I understand 12 and 55 are not issues but the 37 is tc clutch solenoid ckt(an open or shorted condition detected in the ckt circuit) or the trans temp sensor voltage to low or high. I don't know were to start to figure out what is wrong and I don't know what the ckt circuit is. I know you guys on here know your s*** about these trucks so I hope you can help.
Posted from Dodgeforum.com App for Android
Old Dec 5, 2012 | 01:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Disconnect the negative battery cable and turn the headlights on for a minute. Turn the HL's off and reconnect the battery cable and see if the problem goes away. http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
