46re Need help
Old Dec 6, 2012 | 08:37 PM
JohnAxis's Avatar
JohnAxis
Default 46re Need help
Ok I swapped a 5.9 and 46re in to my jeep tj the Trans is a remand unit.
When I first started the jeep I took it around the block no problems at all and never when over 20 mph. Then had it towed to an exhaust shop when I went to drive it home everything was good and strong for the first mile then nothing just went in to neutral. I could rev it and nothing at all. Then i shut it down for a min or two started it back up everything was fine except for the trans was making a whining noise like a low power steering pump then within a min or two right back to neutral. Trans fluid levels are good.
Any one got a clue on this?
i know it's not a dodge but i just need help from someone that know this trans.
Old Dec 6, 2012 | 09:03 PM
Nereaga's Avatar
Nereaga
Did you check the fluid when trnas was in N? Checking in D will give you a false reading. Also needs to be warmed up to normal operating temp...
Old Dec 6, 2012 | 09:08 PM
JohnAxis's Avatar
JohnAxis
i checked it in N and just now i pulled the trans cooling line and i got a lot of fluid form it when i started it for a few sec so i think the pump is working.
Old Dec 6, 2012 | 09:10 PM
stewie01's Avatar
stewie01
You say remand unit, is there still any warranty left or has it expired?
Old Dec 6, 2012 | 09:12 PM
JohnAxis's Avatar
JohnAxis
The project took so long I didn’t get it in before it expired.
Old Dec 6, 2012 | 09:30 PM
JohnAxis's Avatar
JohnAxis
Well never mind guy I let the jeep run tell the Trans started to act up again then disconnected the cooling line and there is not flow at all
Old Dec 6, 2012 | 09:34 PM
stewie01's Avatar
stewie01
Check valve delete needed maybe?
Old Dec 6, 2012 | 09:36 PM
JohnAxis's Avatar
JohnAxis
No check valve I read on here all the problems with them so I never installed one when I build the jeep.
Old Dec 6, 2012 | 09:42 PM
stewie01's Avatar
stewie01
Oh. Well I've got no idea what to tell ya. Others might chime in later or tomorrow.
Old Dec 8, 2012 | 02:56 PM
JohnAxis's Avatar
JohnAxis
ok droped the pan and found brass and steel in the filter and magnet and some type of fiber in the pan.
so is it time for the tranny shop or would a new TC and maybe a new pump work?
