Cant shift out of 2h, knowledge requested
#41
No, I'm not any percent sure but merc was pointing toward the same thing...i got wrapped up with dinner company but let me run out now and see if i can get an answer about wether or not there is any vac in the lines.
#42
Thought this would be a good time to throw this in here...
https://dodgeforum.com/forum/2nd-gen...-shifting.html
#43
ok, so I do have vac at the cad (center axle disconnect)
I put in 4lo and fired it up and then went down to check and sure enough vac sucking away on one line, put it back in 2h and back underneath and sure enough sucking away on the other line so I believe thats a good sign the new actuator and housing i ordered will solve the problem ay?
#45
I cant really verify that it engages at all, I have not been able to block up the truck for a free spin test nor are there any place around the city here where i can drop into some mud and find out but hopefully ill get it up in the air here shortly to confirm.
All i can say is that if i turn the truck off to shift i can confirm it shifts into 4lo and Im fairly certain i can feel it shift into 4h, but again bout all i can say is..truck off shift..truck on drive back and forth..yes...is it really engaged..not sure.
#46
I cant wait til i stop getting these messages and can post up my own avatar pic and sig...itll be like xmas! only...after xmas..
baileysoffroad, you do not have permission to access this page. This could be due to one of several reasons:
- Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
- If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
#47
Did the 4wd dash light come on?
#49
#50
Well, parts should be here in 2 days and Ive got so many other things to go over with no plans of going wheelin in that time i figured i'd just wait an throw the new one in an then post results. That being said we are suppose to get snow monday so it would great if I at least sorta had 4wd.
