Need Help
Old Dec 11, 2012 | 11:23 AM
docslocks's Avatar
docslocks
Default Need Help
1997, 5.2 truck will not crank, fuel pump is working. When I take battery cable off and put it back on it will crank. It might be a couple of days before it happens again. Anybody got any ideals whats wrong.
Thanks Doc
Old Dec 11, 2012 | 11:27 AM
CSDavies26's Avatar
CSDavies26
Are the battery terminals clean and tight? If yes, then check all your grounds and take the truck over to advance auto and get the battery and starter tested. Since it seems to be affected by messing with the battery cable, my feeling is that its an electrical issue somewhere.
Old Dec 11, 2012 | 11:49 AM
docslocks's Avatar
docslocks
Battery and starter are find . I think it has got something to do with resetting the computer chip or something. Anybody know anything about this. Thanks Doc
Old Dec 11, 2012 | 12:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
CRANK? as in the motor does not turn over or the motor won't start? And please, in the future refrain from using thread titles like "need help" in the tech section. Thanks and welcome to DF.
Old Dec 11, 2012 | 12:28 PM
docslocks's Avatar
docslocks
Engine turns over fine. acts like its not getting fuel.Fuel pump is working. Take battery cable off and put back on, engine cranks up and runs fine. Thanks Doc
Old Dec 11, 2012 | 12:35 PM
zman17's Avatar
zman17
Will it start if you hold your foot on the pedal a little?
Old Dec 11, 2012 | 01:17 PM
docslocks's Avatar
docslocks
Starts up fine right now. Will try that next time, probably in the morning. Thanks Doc
